Z Datum Issues
Discussion in 'CNC Cutting' started by EHSFFA, Nov 5, 2018.
  1. EHSFFA
    EHSFFA Member
    Oct 27, 2017
    66
    Big thank you to everyone on this site for the help with my past problems!
    I have a 4400 and it ran multiple parts just fine all day then it started nosediving into the material. I checked this site and found another user with that problem and the suggestion was to reset the torch height. I did this but every time I datum or reset the Z axis the torch goes to the bottom of its travel and will not stop.
    Any help is greatly appreciated.
    Hitting Reset Z and the torch drops indicates a broken wire in the switch assembly for the Z axis. Look on the right side of the breakaway, where the two white square molex connectors plug into each other (red and black wires), look for a broken wire. If not there then remove the black nylon mounting block on the breakaway, behind it is a cover with two Phillips screws, check for a break in the wires there as well.
  3. Dplasmasir
    Dplasmasir New Member
    Sep 16, 2021
    i have a Torchmate x 5x10 and will not Datum it happened one time about 3 days ago. i let it sit for a few hours and it started working again, and been working ever since. now it has stopped working again. any suggestions of possiblle solutions would be greatly appreciated.
  4. LECS Hunter
    LECS Hunter Administrator
    Feb 10, 2021
    49
    43
    Good afternoon, if you haven't already, you can file a support ticket here: https://torchmate.com/technical-support or give us a call at 866-571-1066 for support help.
