VMD 2020 Config Help
Discussion in 'CNC Cutting' started by Forgedweld, May 21, 2020.
  1. Forgedweld
    Forgedweld New Member
    Aug 17, 2018
    66
    I've updated to VMD 2020, and I'm having trouble finding how I change the FlexCut model that the software is using. It seems to default to FC80, and I have a FC125. Thought it may detect the machine model during startup, so have tried cycling power with no success.
    Also, I've been unable to figure out how to get the table feedrate in the integrated tables to override the 100ipm default cut speed from Torchmate CAD files in the gcode. Do I just need to just use the manual override?
    Anyone else go through this?
    Other than that, I'm really impressed with the improved accel/decel in corners, and added features.
    662
    191
    LOG ON.
    ADMIN (password 1234)
    Press OK.
    When the MACHINE SETTINGS opens, up in the upper left you will see a GEAR.
    Press the gear.
    In the COMMISSION ACCUMOVE tab, select your machine and change to the right plasma cutter.
    obviously, HIDE OXY/WATER LEVEL if using a 4x00.
    Press OK and the VMD will restart with the proper settings.
  3. Forgedweld
    Aug 17, 2018
    66
    Thank you, Chad.
    Can you confirm something about the automatically loaded feedrates for me?
    If you load a cutfile from the shape library, does it use the feedrate (from the material thickness you've specified) as the cut speed, and conversely, if you import a cut file from Torchmate CAD, you'll need to manually adjust the cut speed as before the tables were included in VMD with this update?
  4. LECS-Chad
    662
    191
    Shape Library parts go off of the values in the PROCESS. This means you can have one file that will run on multiple materials.
    If you are running out of TMCAD, then you can skip entering the feed rate as SP2 no longer travels at max speed when no feed rate is assigned.
    Just toggle the CUT PARAMETERS to USER DEFINED vs. PROGRAM DEFINED.
  5. RyanLMC
    RyanLMC New Member
    Feb 14, 2021
    These are issues i have had only today great thanks..
    Also my 4800 i have just fitted the laser and installed software service pack 2 but when i press laser the torch comes all the way down and hits the sheet..
    Also when i do a dry run with a shape it follows ok and seems good but when i hit active run it just peirce cuts hole then just stays there and doesnt move?
    Any ideas...
    And do i need to do a laser offset setup or is it pre set with the correct torch hight...
  6. LECS-Chad
    662
    191
    Ryan,
    Did you follow the commissioning and load configuration?
    If you are still having issues, then I suggest reaching out to our support team at 7756732200 ext. 4
