Trying to cut a nice hole
Discussion in 'CNC Cutting' started by Fastyankee13, Apr 17, 2018.
  1. Fastyankee13
    Fastyankee13 Well-Known Member
    Jun 3, 2016
    89
    48
    I have had my growth series for a few years now. Its a love hate relationship for sure.
    When I first set the machine up it made pretty descent bolt holes but since changing to Acumove 2 the quality of my bolt holes well they suck. I did do some adjustments to my lead screw y axes end play which made a huge difference on larger holes but I still can not get a descent bolt hole. see pics. This stainless first time cutting stainless. both sides I also got a lot of curf. second photo is back side.
    Those hole look a little small. With "conventional" air plasma you should be getting 2:1 ration on bolt hole size: material thickness.
    Also changing things like LEADIN radius and those things will also improve your hole quality.
  3. Fastyankee13
    Jun 3, 2016
    89
    48
    The holes are 3/8th in .25 thick stainless.
    I did notice my machine making terrible circles. So I started looking at the leed screws and they were tolerably out of wack. Tightened all that up and shes running good. But when I do bolt holes no good.
    I guise I'm better off doing a pierce only But I'm not sure how to go about that. I usually use a good grade reamer on my bolt holes. How do I do just pierce so it ends up in the center of were the hole needs to be.
    I feel bad for Ziggy when he gets me in class in June.
  4. LECS-Chad
    Pierce only is generating a 1/8" circle and when you generate the tool path you will get a pierce hole. Drill from the backside then you wont be killing bits.
  5. Fastyankee13
    Jun 3, 2016
    89
    48
    I guise the challenge would be placement were the center of the hole needs to be.
  6. Doing Well
    Doing Well New Member
    Sep 18, 2017
    Have you ran a speed test on the holes? You might need to slow your speed on the holes.
