Torch Diving
Discussion in 'CNC Cutting' started by drweld, Nov 17, 2022.
  1. drweld
    drweld Member
    Oct 25, 2017
    Our Torchmate 4400 seems to have a problem with the torch diving into the material. We set up the plasma cutter with a job and tried to do a dry run to check the program, but the torch continues to dive into the material no matter what we change in the parameters. It almost seems like the torch is not sensing the material. Unsure what is wrong, any suggestions?
  2. LECS Hunter
    LECS Hunter Administrator
    Feb 10, 2021
    49
    43
    Good morning, you can submit a support ticket here: https://torchmate.com/technical-support or give us a call at 775-673-2200 and someone from our support team will be able to help.
