Switching VMD Datum Zero Location?
Discussion in 'CNC Cutting' started by J-Nol, Jun 30, 2019.
  1. J-Nol
    J-Nol New Member
    Oct 1, 2016
    I moved my table to a new shop and when I put it back together, the zero is at the bottom right of the table instead of the bottom left. Is there a way to change the zero setting in the VMD to have the machine datum in the bottom right? Or do I have to take the gantry apart and flip it (because I would rather not do that).
    698
    You must of assembled the gantry 180 out from when you took it apart. Short from swapping two of the wires on the motor cable you will need to flip the gantry back around from where you had it originally.
