Roll form steel supply
Discussion in 'General Fabrication' started by Jerry Harlow, Jan 9, 2017.
Tags:
  1. Jerry Harlow
    Jerry Harlow New Member
    Jan 9, 2017
    I have been looking for a small supply of roll formed steel to use on converting a bus into a motor home. Back when I was in high school the called it cold rolled. I haven't used the stuff for 40 years now the people at the steel yards look at me like I am asking for moon rocks. the structural angle and channel is too heavy to use and wont fit with what the bus is made out of. It is a 2008 Champion 25 footer on an F450 chassis. What I need to know is who supplies standard roll formed steel, or if I am searching for the wrong thing (is it called something else now)?
    TIA JH.
    PS. I am new to the forum, so if I posted this in the wrong place I apologize.
  2. LECS Tim
    LECS Tim Member
    Oct 12, 2016
    19
    8
    Understand I am no expert but "Roll formed steel" is more of a process then a product.
    I would say go HERE see if you can find what you need then find someone near you that sells it. I hope that helps.
  3. Jerry Harlow
    Jan 9, 2017
    Thanks for the suggestion, what they sell is the hot rolled or structural steel. The legs of the channel and angle iron have tapered cross sections, what I am looking for is angle and channel that have a consistent cross section, like a rectangular tube with one or two sides removed. The bus I am working on has a bunch of 2 x 2, 1.5 x 1.5, 1.5 x .75 channel and 1.5 x.1.5 angle all about 0.080 thick used for the framing. I have also seen it used in steel buildings (the pole barn type), but no one seems to know where it comes from. If I can’t source the stuff my only recourse will be to rip (a wood working term) some square tubing into channel, an effort I want to avoid if possible.
    JH.
  4. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    156
    10
    88
    you want architectural , not structural the latter has what they call a web joining the two,.much stronger
  5. Jerry Harlow
    Jan 9, 2017
    Thanks I had not tried "architectural". I did a google search and the only people that supply it in mild steel seem to want to make it. I need a couple of lengths of 1-1/2",2", & 3" channel and about 3 lengths of 2" angle all 0.060-0.080 thickness. Does any one know where I can source the standard sizes without having then custom made? I am near Portland (Mud city) Oregon. TIA JH.
