Plate Marker Issues
Discussion in 'CNC Cutting' started by EHSFFA, Feb 18, 2019.
  1. EHSFFA
    EHSFFA Member
    Oct 27, 2017
    We recently installed a platemarker to our 4400. We followed the instructions and have our offset set up. The issue is when we run the file the platemarker moves to the right location but doesn’t go down to touch the steel. It will move through the entire file but never move down. Air pressure is showing on the gauge to be within the parameters.
    Any help is greatly appreciated!
    660
    Check that your interface wires are connected to port 2 on the back of the Accumove controller, the polarity of the wires do matter so try swapping the wires.
  3. EHSFFA
    EHSFFA Member
    Oct 27, 2017
    When you say swapping the wires are you taking about unhooking the wires from the back of the adapter that plugs into the accumove and swapping them? I ask because how they are is the way it came from the factory.
    I manually started the platemarker today and it shot down to the plate like a bullet.
    Thanks for your help!!
