Operated Table Without Side Covers and The Rail Bearings Fell Out
Discussion in 'CNC Cutting' started by Michael Franz, Aug 5, 2021.
  1. Michael Franz
    Michael Franz Member
    Jul 6, 2021
    8
    Hey guys,
    Long story short, I decided to operate our 4800 without side covers to make sure it was moving across the rails right (not knowing that the side covers also serve the purpose of keeping the machine head from over-reaching). When I pressed the DATUM button, it moved in the forward Y directing until half of the first slider was hanging off the rail (it was at this point the gear ran out of teeth and it stopped). About 12 bearings fell out. After discovering that it would cost around $3000 to repair the machine, I fed all but one bearing back in, (had to clock out). My question is, if some bearing(s) are lost, do any of you know the diameter of the bearings, and where I can get them?
    Michael
    Torchmate 4800
    Accumove 2
    LECS Hunter likes this.
  2. 61 Sunliner
    61 Sunliner Active Member
    May 22, 2016
    34
    3000.00 to repair it?? Yikes!
    If somebody doesn't know the size (I don't, I have a growth series) grab a micrometer or dial caliper and measure one. Hopefully it is a common size and Gooogle it. Even Amazon and EBay sell loose ball bearings. I bought a bag of 100 cheap to weld on for feet for napkin holders and letter holders I was cutting.
  3. Michael Franz
    Jul 6, 2021
    8
    Thanks for the reply,
    I should of updated this earlier, but I was able (God only knows), to recover all the ball bearings and feed them back into the rollers, needless to say the torch now operates fine. If there is anything I can say after that terrifying experience, it's always follow every little instruction in the manual. It may be a state-of-the-art piece of equipment, but it only takes one push of a button to jack it up bad.
    Michael
    xardion likes this.
  4. Jerryandre71
    Jerryandre71 Member
    Dec 18, 2020
    3K price sounds way high to me.
    I used to build machines with linear rails and bearings. Bearings ranged in price from $60-$200 each depending on type and size.
    Once you have replacement sliders they aren't to hard to swap out if you needed to.
    But glad you go it working!
  5. LECS-Chad
    The $3000 charge was to have a factory-trained tech out of Reno, NV to arrive and replace/realign the table.
    Currently, the cassettes are available for sale, without requiring on-site service.
    You can reach out to our parts team to get a quote. parts@torchmate.com
