My First Projects
Discussion in 'DIY Projects' started by Joshua Milner, Dec 7, 2017.
  1. Joshua Milner
    Joshua Milner New Member
    Nov 27, 2017
    Using 16 gauge steel on everything. Not a fan so far to flimsy. I will Start with some 14 gauge stuff soon. Raiders was done cuting 3 different pieces. One was grinded down to a mirror finish and I tossed it into the laser to engrave all the little logos and sayings. Going to mount some chains from the shield to the name plate to complete the look.
    Other is just a Xmass tree cut out & grinded shinny with a little bow tied at top.
    last is snowmobile art, I was practicing trying to blue metal with a torch. Didn't come out way i wanted but its an art form i hope to learn. The trees are cut out with the laser and just frosted to make them look like snow.
    nwaPLASMA likes this.
  2. Galen Nelson
    Galen Nelson Member
    Aug 30, 2017
    12
    looks great, we just got our machine fired up and are waiting on some water additive. Keep up the good work!
  3. LECS-Chad
    625
    186
    14 gauge is the way to go... looks good and keep it up. Looks like you need to work on those bridges in your letters. Good rule is 3x times the thickness of the kerf diameter 40-45amp @ .058 x 3 = .174"
  4. nwaPLASMA
    nwaPLASMA Well-Known Member
    504
    255
    Ditto on the 14g. It seems to be just the right thickness for art. Not to flimsy yet not to heavy to safely hang. I have started using .100 bridges with fine cut consumables. With regular shielded consumables I wouldn’t go below .125. All at 45a
  5. nwaPLASMA
    504
    255
    What laser engraver are you using? Pic?
  6. Cneee
    Cneee Member
    Jan 7, 2018
    7
    great work. any updates on the laser engraver you're using?
  7. Motobilt
    Motobilt Well-Known Member
    Apr 6, 2016
    83
    94
    48
    Nice work
