metal build-up on cap
Discussion in 'CNC Cutting' started by Rod Back, Dec 18, 2019.
  1. Rod Back
    Rod Back Member
    Feb 19, 2016
    12
    I have a problem with molten metal building-up on the cap while the torch is making cuts in the clockwise direction. Cuts fine when cutting in the counter-clockwise direction. When a large amount builds-up, the torch will either stop cutting or crash into the metal. Anyone else have this problem currently or in the past?
    699
    I havent hard of any issues such as that before, you can try anti splatter spray, spray it on the cap to prevent the material sticking to the shield cap.
  3. Rod Back
    Rod Back Member
    Feb 19, 2016
    12
    I've tried that. It helps some, but within a couple of cuts it starts building up again. I was wondering if it has something to do with the oil film that is on the cold rolled sheets. I'll take a picture and post for you to see. Thanks
