Internally LED lit sign
Discussion in 'DIY Projects' started by nwaPLASMA, Jul 30, 2017.
  1. nwaPLASMA
    nwaPLASMA Well-Known Member
    504
    256
    This guy has a podcast. This was for his studio room. About 38" wide.
    626
    187
    That turned out really nice. great layer job on that!
    nwaPLASMA likes this.
  3. OcalaWill
    205
    Really nice! Did you have to roll the sides or could you bend and weld as you go?
  4. nwaPLASMA
    504
    256
    Bend and weld. 20 gauge. Next time I'll use 22g. The 20g was a little stiff for the tight angles and tolerances.
    I should have taken build pics. I cut rings that set about 1/2" inside the outside diameter of the sign and followed the same contour, then bent the 20g around the rings after I welded the rings to the front and back.
    OcalaWill likes this.
