Humvee Build
Discussion in 'Rockstar Garage' started by NicAshby, Sep 20, 2016.
  1. NicAshby
    NicAshby Member
    Aug 29, 2016
    21
    23
    This will be one of the builds that gets pretty techincal with what we need to build.
  2. Matt
    Matt Well-Known Member
    112
    This thing^^, idk i kinda like it as it sits there lol cant wait to see how its built up though
  3. Torchmate
    Nov 25, 2015
    249
    Very interested to see what you do with this!
  4. El Jefe
    El Jefe Advanced User Staff Member
    Dec 1, 2015
    120
    62
    Looking forward to this build.
  5. NicAshby
    NicAshby Member
    Aug 29, 2016
    21
    23
    heres a quick update on the Humvee build...
    First thing we needed to do was remove the old cowl and get two brands in their that titled the build in support. Odyssey Battery and Bulletliner, when we started cutting the cowl the problem we found was the actual hole in the hood was not square
    LECS-JR likes this.
  6. NicAshby
    NicAshby Member
    Aug 29, 2016
    21
    23
    Needing zero approach angle in moab or on any trail is always a a goal, plasma cutting 1/4" sheets down to a flat bumper is always a plus! being able to add in our own logo makes it that much more... behind that bumper we needed to install a 12k winch able to recover these heavy beast if needed! Luckily Warn had one that would drop right in between the frame rails... Luckily the base plate and braces we'er an easy task. Here's a hint cut out the part in cardboard and scan the file in to AI or Torchmate Cad and boom then alter as needed! IMG_3467[1].JPG IMG_3464[1].JPG IMG_3456[1].JPG
    Now on to the new rads and intercooler for the 5.9 cummins swap!
    LECS-JR likes this.
  7. NicAshby
    NicAshby Member
    Aug 29, 2016
    21
    23
    This thing was picked up with allthe factory coolers on it but little was done beyond the 5.9 swap it was about 70 percent conplete.
    So heres some breakdown shots of how it looked before and after the new rad and intercoler was installed from Mishimoto IMG_3388.JPG
    Now time to start installing the rad, intercooler and oil cooler
    The setup is awesome with dual fans built for both the intercooler and rad its pushing over 8,000 cfm.
    Time for the oil cooler!
    You'll see it hidden below the Mishimoto logo that CNC Plasma cut on our table along with all the shrouds!
    So that portion is all ready to go now to install a center console!
    LECS-JR and DrewP like this.
  8. El Jefe
    Dec 1, 2015
    120
    62
    Cool Build, I like how you are incorporating the branding in the parts.
  9. Matt
    112
    Looking pretty good
  10. Jakes welding & fab
    Jakes welding & fab New Member
    Oct 1, 2016
    Looks good how is the fuel tank set up ? Still inside the frame and are you guys running a body lift ? I have mine mocked up now thinking I'm going to have to run a fuel cell somewhere else and I am going to need a 1 1/2 body lift to clear the front drive shaft
