Height control
Discussion in 'CNC Cutting' started by audigger, Aug 22, 2019.
  1. audigger
    audigger Member
    Feb 2, 2019
    7
    Have a 4x4 growth series table - accumove 2 . Today when i cut a object it stopped. So i start from beginning. Only way to move is to press reset? The height control motor is moving on its own until i press a up or down arrow . press the stop button a couple times , press run button the stop button high lights ? Never had this problem before ,and i think it will correct after the accumove is turned off for a time. intermittent issues are the hardest to solve ?
    Verify some settings on your Config, Logon as Admin go to Machine Settings then Inputs Tab, check the Debounce Times for Breakaway 1 and 2 are set to 300 and Cap Sense is set to 10. To resume from a pause you may need to press Reset, leave the torch where it is at, zoom into your part where it stopped at, the white cross hairs is your torches present position, right click on the cross hairs and press Run From Here. Press Run Job after software finds the position to resume the job.
