Fire pit design 1
Discussion in 'DIY Projects' started by Dan Turner, Sep 8, 2016.
  1. Dan Turner
    Dan Turner Well-Known Member
    48
    26
    93
    People have been asking me to post how to draw the fire pits that I make. The first thing to know is that you will use hexagons and pentagons. The second is to decide how large you will want the fire pit to be. We usually will use 6.5"- 8" sides the smaller shapes will usually fit onto one sheet of material. We will usually use 12ga material.
    To help with the sizing of your shapes, I use a website:
    http://www.calculatorsoup.com/calculators/geometry-plane/polygon.php
    This enables me to play with the shapes and measurements until I get my desired size. Make sure that you change the measurement to inches or centimeters, and you desired significant figures
    For the pentagon for example, if I desire the side to be 6.5” the R would be 5.53” for hexagons, it is easy, the number of sides to 6 and the R to 6.5”
    Make sure that you convert the shapes to a polyarc. For the base and fill pieces, you want to cut a hexagon in half and use those pieces. I usually use the ginsu knife function for this. Or use the node edit and click on the middle garbage button on the bottom edit tool row and delete the line segments you do not need. Then I click on the middle button on the top edit tool row and highlight the two nodes you want to connect and hit “J” on my keyboard.
    Once I get my desired size and shapes, I start to insert and drawn the designs I want.
    sahbi, Anna Tivol, nwaPLASMA and 3 others like this.
    655
    189
    Great walk-through... I might "borrow" it.;)o_O
    Matt likes this.
  3. Dan Turner
    48
    26
    93
    You can borrow it anytime you wish
  4. LECS Mark
    Dec 1, 2015
    79
    51
    48
    Dan thanks for posting this! These are by far the coolest fire pits I've ever seen. I'm glad that multiple people will be able to use this design!
  5. Charlie Preston
    Charlie Preston Active Member
    Apr 17, 2016
    27
    23
    8
    Here is a DXF for the pit that I use and a pattern of what you need to make one. I think it is about 30 in diameter. I use it as a base to make different pits. eagle pit.jpg eagle pit.jpg
    sahbi, nwaPLASMA, mco_1 and 1 other person like this.
  6. Dan Turner
    48
    26
    93
    Charlie, That is awesome. It is amazing how creative some people are.
    Charlie Preston likes this.
  7. Charlie Preston
    Apr 17, 2016
    27
    23
    8
    Just trying to keep up with you
  8. Dan Turner
    48
    26
    93
    Charlie, thank you for the kind words,
  9. Wes Berndt
    Wes Berndt New Member
    Oct 25, 2016
    What is a .CDL
  10. Dan Turner
    48
    26
    93
    .CDL is a file format that will open in the Torchmate software
  11. Manuel
    Manuel Member
    Apr 19, 2017
    22
    Thanks you guys! I'm a very lucky to have a the support here on the Wild West!
  12. Manuel
    Manuel Member
    Apr 19, 2017
    22
    Dan,
    Thank you very much. My Math Teacher were also very help but this is a great tool when they are not available!
    Thank you!!!
  13. Fastyankee13
    Fastyankee13 Well-Known Member
    Jun 3, 2016
    89
    48
    Dan,
    Thanks brother for sharing the file. I was just asked to build one of these.
  14. sahbi
    sahbi New Member
    Jul 16, 2019
    THANKS FOR SHARING
