Edu file to Cdl file
Discussion in 'CNC Cutting' started by Kchoghead, May 11, 2019.
  1. Kchoghead
    Kchoghead Well-Known Member
    200
    27
    I have a teacher friend that i am helping getting his growth series 4x4 edu version back up and running . He sent an edu file to work on and i couldnt open it in cad v9. what is the fix for this
  2. Kchoghead
    200
    27
    will an edu version of cad open a cad .cdl file
  3. Dnmeistr-LECS
    660
    Yes Edu version of Cad will open both file types, though normal Cad will not.
  4. Kchoghead
    200
    27
    the file that my teacher friend sent me (dfx) when i imported it into cad 9 had double lines throughout the file. I cleaned it all up and put on usb stick(cdl) , took it to him . when we opened the cleaned up file in his edu version 9 . the double lines all came back. I have had double lines from imported filed before but never experienced this before. Could his edu version be causing the double lines?
  5. Dnmeistr-LECS
    660
    Are you creating a tool path and showing the original as well as the tool path, that would be a double line. The edu version operates the same as cdl version, just different native file extensions.
  6. Kchoghead
    200
    27
    no toolpath created when saved......I understand if that were the case but not in this instance
