DIY TM side rails, table etc
Discussion in 'DIY Projects' started by BlueSteel, Sep 13, 2017.
  1. BlueSteel
    BlueSteel Well-Known Member
    Dec 15, 2016
    99
    48
    I have a spare 2x2 gantry, anyone ever build their own side rails and table for it? Debating on what to do with it. I'd like to make it a 2x4 table and something other than a drivescrew. Looking for ideas
    620
    186
    It would be pretty simple as there isnt much to be desired on the mechanics of the GS tables.
    Ive heard of some people eliminating the lead screw and going straight linear rail instead while adding rack and pinion setup. Might be best to look for a used/scrapped 4x4 and grab the sides.
  3. BlueSteel
    Dec 15, 2016
    99
    48
    Nobody around here even knows what a torchmate is. I really want to do linear rails to get some better speeds. By chance you don't happen to have pictures or anything?
    would be great if Lincoln came out with a bolt on upgrade kit for the GS stuff.
  4. LECS-Chad
    620
    186
    Google is your friend...
    The GS machines were discontinued so there will be no more HARDWARE upgrades to that machine.
  5. BlueSteel
    Dec 15, 2016
    99
    48
    I have been looking, haven't found a damn thing
  6. nwaPLASMA
    nwaPLASMA Well-Known Member
    504
    255
    I think it would be fairly easy to convert it to two vertical motors and a gear rack setup like other TM tables.
  7. BlueSteel
    Dec 15, 2016
    99
    48
    I never seen another TM table setup like that. Is that how yours is?
  8. nwaPLASMA
    504
    255
    Yes. Two vertical motors on the gantry running on two gear racks mounted to the inside of both sides of the table.
  9. BlueSteel
    Dec 15, 2016
    99
    48
    got a pic?
  10. Dnmeistr-LECS
    640
    106
    Like was mentioned earlier there are a ton of pics out there, look at TM1, TM2, TM3, TMX all have rack and pinion.
  11. LECS-Chad
    620
    186
    Check this out...
  12. nwaPLASMA
    504
    255
    Nice conversion!
