cleaning holes
Discussion in 'General Fabrication' started by ablecnc, Jan 25, 2018.
  1. ablecnc
    ablecnc Active Member
    Dec 11, 2016
    21
    when plasma cutting holes what type of drill bit is there that can drill threw the temper part I jus burn bits up
    655
    189
    yupo...
    I personally make a .060 size hole for a drill center and just use it for placement. Under-sizing a hole and trying to drill empties the wallet with ruined drill bits.
  3. ablecnc
    Dec 11, 2016
    21
    what the dill are you using after the material is tempered due to heat
  4. Larry Cameron
    146
    29
    I use a cobalt drill bit. Well I think they are about 5% cobalt.
    Larry Cameron
    RusticMetalArt
    Don Powell Jr likes this.
  5. Kevin Lipka
    Kevin Lipka New Member
    Jun 16, 2018
    Go to harbor freight and get the warrior brand step bits they drill with ease and last a long time for up to 1/4" thick. For thicker I don't plasma cut the holes.
