Box dividers
Discussion in 'DIY Projects' started by nwaPLASMA, Jul 30, 2017.
  1. nwaPLASMA
    nwaPLASMA Well-Known Member
    506
    256
    14g box dividers for a customer. 76 dividers broke on two sides. Break lines sure make it easy. Second pic is dross right off the table. Having really good results with 14g.
    OcalaWill and LECS Mark like this.
  2. LECS Mark
    Dec 1, 2015
    79
    51
    48
    What are your cutting parameters for 14 gauge? HRPO?
  3. nwaPLASMA
    506
    256
    Its just HR.
    210ipm
    45amps
    85volts
    Shielded fine cut consumables on Hypertherm powermax 85.
    OcalaWill likes this.
  4. LECS-Chad
    655
    189
    14 ga is perfect fo rthe smaller projects. one of the sizes we use the most. Im at the same settings!
    nwaPLASMA likes this.
  5. OcalaWill
    205
    When you do a bend line (cut) is that just a line with online cut path or is there a closed narrow rectangle to it? I have never tried that. Looks great!
  6. nwaPLASMA
    506
    256
    Just a straight line with an online tool path. Works great for stuff like this. I usually leave 1/4" at the connection points. Then just break it over the edge of a table. Any less than 2 or 3" on either side and it works best to sandwich it in a vice between two pieces of angle iron that are longer than your part.
  7. OcalaWill
    205
    Thanks!
  8. LECS-Chad
    655
    189
    and if you want the "solid" look then you can fill weld the bends and grind. smooth operator.
