1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Blue AVHC lifter
Discussion in 'CNC Cutting' started by BlueSteel, Feb 6, 2019.
  1. BlueSteel
    BlueSteel Well-Known Member
    Dec 15, 2016
    95
    48
    Lifter is a little noisy coming down to touch the plate but quiet going up. That normal? I lubed it up
    Also why in the world is that little smart motor so expensive? saw it online for $1500! That's half the price of the entire avhc setup
    592
    102
    Too much lube is a detriment has diminishing returns, keep it well cleaned and very lightly lubricated a couple drops of 3 in one oil on top of bronze nut is all you need. As well as wipe chromed guide rods down with silicone spray, spray on a rag and wipe the rods down.
  3. BlueSteel
    Dec 15, 2016
    95
    48
    Will do. Any idea on the noise?
  4. Dnmeistr-LECS
    592
    102
    Noise is either coming from lead screw/bronze nut or the bushings inside the lifting block.
  5. BlueSteel
    Dec 15, 2016
    95
    48
    Dirt or time to replace parts?
  6. Dnmeistr-LECS
    592
    102
    I would go through it dissassemble and clean everything, clean the lifting block as you would a gun barrel, run pieces of rag down through the bore holes, clean guide rods with silicone spray, clean lead screw with wd40. Reassemble and lightly lubricate bronze nut/lead screw with 3 in 1 oil by using 2 or 3 drops.
