Adjusting Cut Parameters
Discussion in 'CNC Cutting' started by Jerryandre71, Jul 31, 2021.
  1. Jerryandre71
    Jerryandre71 Member
    Dec 18, 2020
    I am trying to adjust cut settings on my machine (4510 w FlexCut 80) manually.
    I have a drawing i produced with a cut speed of 12 (trying to cut 3/4" mild steel)
    On the process screen i changed the cutting speed to 9. But on a dry run the feedrate still shows a speed of 12.
    Do i need to redo the drawing and cutting tool path each time?
    I also need to adjust pierce height and pierce delay.
    Can any of these settings be adjusted while i am producing my drawings and cutting tool paths?
