? about 200 Square Wave
Discussion in 'Welding' started by Jeff Tures, Jan 4, 2017.
  1. Jeff Tures
    Jeff Tures Member
    Feb 29, 2016
    7
    66
    I've recently bought a 200 Square Wave Tig machine. My experience is limited with tig. I seem to be able weld mild steel OK, but 1/8" aluminum I'm trying to weld is a nightmare. I have it set on AC Tig and the other settings as the manual says to do. Buy the way Lincoln, your manual sucks. All I get is a funny fuzzy flame that doesn't melt anything. I cleaned the aluminum with a stainless steel wire wheel before welding.
    Any help is appreciated.
  2. BlueSteel
    BlueSteel Well-Known Member
    Dec 15, 2016
    101
    88
    What are your settings? I don't use that welder but I am pretty good with aluminum.
    General settings for 1/8" I would use 140 amps, 65% EN and 100hz
  3. Dnmeistr-LECS
    Youtube is generally sufficient and better than reading a manual.
    LECS-Chad likes this.
  4. Jeff Tures
    Jeff Tures Member
    Feb 29, 2016
    7
    66
    My setting were 140 amps, 60% EN and 122hz
    Jeff
  5. BlueSteel
    Dec 15, 2016
    101
    88
    So what's the problem? Smash the pedal until you get a molten puddle, back off a little, dab and move, rinse repeat.
    Less thinking and more doing. Aluminum likes to be welded faster so just move on out!
    60% is a little low IMO if it's clean material. Miller defaults their stuff to 72-75% depending on the machine. I tell people 68-72% is an all around great spot to be in
  6. DrewP
    DrewP Member
    Aug 24, 2016
    11
    8
    What color tungsten? You shouldn't run green. Red works, purple, LaYZr is also good for Al and anodized Al. Also you don't need to ball it because it is an inverter, if you are trying to ball green. You should go more % EN then 60% if it's not building a puddle.
    If you have more specific questions you can call Lincoln Electric's applications department hotline or live chat with some experts.
    866-635-4709
  7. Jeff Tures
    Jeff Tures Member
    Feb 29, 2016
    7
    66
    I'm using 2% Lanthanated. I was looking at articles on Welding tips & tricks and read that maybe I had the argon set too high. I'm not sure were that should be exactly. I made a few adjustment and now I'm getting a puddle. I used a tig in school about 6 years ago and had no problem with aluminum there. But then again the teacher told us exactly how to set up the machine.
  8. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    156
    10
    88
    Does that machine have auto setting ? I always ball my tungsten first around 16 cfm argon.
  9. BlueSteel
    Dec 15, 2016
    101
    88
    That won't help him.............
    No need to ball the tungsten as these are inverter welders.
    Next a good rule of thumb to get started is your gas flow should be double (roughly, remember this gets you in the ballpark, it's not perfect) the size of the cup. So a #10 cup should be around 20 cfh
    EAsh likes this.
  10. bigjoe
    Jul 21, 2016
    156
    10
    88
    Do still sharpen it for stainless? Can you explain why the inverter makes the ball negligible, Just asking
  11. BlueSteel
    Dec 15, 2016
    101
    88
    The rule of thumb is to sharpen it to a point for steels and stainless. For aluminum you sharpen it to a point then put a blunt on the end.
    With a sine way it tends to ball up anyway, doesn't happen with inverters which use square waves. They may round off very slightly but nothing compared to a inverter. Plus with adjustable frequency having a point will help you pinpoint and focus the arc. with most transformer machines you are stuck at 60 hz so that wide arc and ball just seem to flow nicely together. Hard to narrow and arc with a big ball on the end of the tungsten.
    That's my .02, others may see it different
  12. Jeff Tures
    Jeff Tures Member
    Feb 29, 2016
    7
    66
    That's what Lincoln has printed all over their directions. See Attachment.
  13. Jeff Tures
    Jeff Tures Member
    Feb 29, 2016
    7
    66
    No auto, but it does have defaults.
  14. bigjoe
    Jul 21, 2016
    156
    10
    88
    Ok , just wondering . I have a precision tig 185. Older machine I"ll just keep ballin
  15. Jeff Tures
    Jeff Tures Member
    Feb 29, 2016
    7
    66
    I don't think the 185 is an inverter machine is it?
  16. BlueSteel
    Dec 15, 2016
    101
    88
    it's a transformer
  17. bigjoe
    Jul 21, 2016
    156
    10
    88
    I like the pulser feature , has most of the bells and whistles but pricier than the new inverter 200 , I don't even know if they make it anymore
