Best epoxy/adhesive for steel and aluminum
Discussion in 'General Fabrication' started by Arkansas Metal Art, Nov 4, 2016.
  1. Arkansas Metal Art
    269
    Anyone have recommendations for a good adhesive for bonding steel to steel or aluminum to aluminum? I've been using Gorilla two part epoxy found at Lowes etc but I can knock it apart pretty easy on aluminum. Thxs
  2. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    156
    88
    Get a small tube of 3-M. Polyurethane marine sealant , couple of small dime size squeezed out Inbetween Will hold pretty much anything. They have a fast cure as well. 5200. Or 4200
  3. Arkansas Metal Art
    269
    Thxs
  4. Harlan Cooper
    Harlan Cooper Member
    Mar 2, 2017
    15
    Bondo works too in between the two pieces.
  5. OcalaWill
    OcalaWill Well-Known Member
    Jun 22, 2016
    206
    37
    What no JB Weld? I love that stuff. Not the 5 minute, but the regular kind. Make sure both pieces have a good mechanical surface to bond to. If you don't mind some flex between parts I concur with the urethane adhesive.
  6. andymo
    andymo Member
    Apr 8, 2017
    9
    I have had good luck with JB Weld also. Just make sure that the surfaces are clean before using it.
  7. Arkansas Metal Art
    269
    Finally found something that's works great on metal.
    [​IMG]
    Harlan Cooper likes this.
  8. Keith Thomas
    Keith Thomas Member
    May 26, 2017
    8
    I recently seen HTS 2000 which is for aluminium to aluminium bonding and it looks really impressive.
  9. bigjoe
    Jul 21, 2016
    156
    88
    Will try it , the 5200. After opening will harden up in the tube in no time
  10. Scott Peth
    Scott Peth Member
    Aug 25, 2017
    If you know anyone in the bucket truck/digger derrick production industry... they use a pretty aggressive adhesive in the fiberglass/steel mating section. Not sure what it's called, but it will adhere to steel as long as the surface is clean. It's a two part glue/activator and it gets really hot once it's mixed, so depending on your application it may or may not work well.
  11. JoeRob
    JoeRob Active Member
    Nov 9, 2016
    28
    Be very careful with the 3m 5200 if you go that route. This stuff is almost impossible to remove. Have you ever seen the aftermath of a storm on a body of water, where at the dock a boat is missing ? Where the lines are still attached to the dock on one end and the other end is still tied to a cleat that was ripped from the boat? Thats the 5200 doing its job. The hull of a boat will rip apart before the 5200 . The 4200 is less aggressive. All depends on what you need it to do......
    Arkansas Metal Art likes this.
